3825 MGCP Transcoder is down
Apr 12th, 2007
I am after advice regarding using a 3825 as a transcoder wih CCM 4.1 and MGCP
The 3825 is running on IOS 12.4(5a) with MGCP
The transcoder is configured on CCM as "Cisco IOS Media Termination Point"
Description and device name are the 3825 chassis MAC address.
The registration is unknown and the IP address field is blank
On the gateway the DSP shows as admin down
The gateway is up and is taking calls via the ISDN PRI no problem.
On the gateway Sh DSP Farm all results in
Admin State: DOWN, Oper Status: DOWN - Cause code: ADMIN_STATE_DOWN
Any advice on where I should start with this ?
lagos Thu, 04/12/2007 - 17:13
1st - Making sure shutdown is not in the dspfarm profile config.
You should see the IP address update even if there is a registration problem.
andym1iptech Fri, 04/13/2007 - 00:56
We have the following entry
isdn switch-type primary-net5
voice-card 0
no dspfarm
no local-bypass
Sorry but I was told previously that it was not necesary to do any config in the gateway as CCM would download it via the MGCP config, is this not right ?
