Configuration of VWIC-2MFT-E1 between two routers
Apr 12th, 2007
Hi there,
I have two Cisco 2851 routers each with a VWIC-2MFT-E1 module. What kind of cable should I use to connect them point-to-point in a close distance and if possible any working configuration.
Klean...
royalblues Thu, 04/12/2007 - 23:37
Yes a back to back T1/E1 cable works
1--4
2--5
HTH, rate if it does
Narayan
minumathur Thu, 04/12/2007 - 23:46
You need to use cross cable , with pin detail are below
1--4
2--5
4--1
5--2
if i am recall correctly , 1&2 are RX and 4&5 are TX.
-Minu
please rate this post.
