Warning message
Copy with Lines - CM 5.1
Apr 12th, 2007
  • Purple, 4500 points or more
Not sure if this is a bug, but when you try to copy a phone with Lines, it copies and creates the new phone and you can enter the new mac and save the new phone. After this, I am not able to modify any setting on this newly copied phone. The error you get is..
Update failed. [491] The specified name has invalid characters or is not formatted correctly for this device type.
Anybody know what error 491 is ?
When you click the save button you also get a popup saying, Keysize (Bits) is required. Please specify a value and try again. Authentication Mode - is Required. Please specify a value and try again.
Note that the callmanager cluster is not a secure cluster and i am not using encryption.
Overall Rating: 5 (3 ratings)
Rob Huffman Thu, 04/12/2007 - 12:01
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Sankar,
Here is the bug that you are hitting. You won't love the workaround :(
CSCsg20564 Bug Details
Unable to save device config after performing 'Copy x/Lines'
Symptom:
It was observed that after copying a 7960 phone with lines, that the new phone appeared to be created in the database correctly. However after making a modification to the new phone and performing a save, the CallManager stated the following error:
"Update failed. [491] The specified name has invalid characters or is not formatted correctly for this device type."
Conditions:
The above issue is also causing problems for the registration of the phones. When you make a Copy w/lines of a phone and you try to register that phone, its giving an error like "Registration Rejected".
Workaround:
1. Re-create the 2nd phone manually
Steps to reproduce:
1. Build a 7960 phone in CallManager
2. Copy the phone using 'copy w/lines' button
3. The new phone config will be created
4. Make a change to the device page of the new phone
5. Click the save button - the error message will be displayed
Hope this helps Shanky (This is one of the features I was quite looking forward to)!
Rob
thisisshanky Thu, 04/12/2007 - 13:53
Thanks Rob!!
Didnt expect that to be the work around. Thats what i am doing right now anyway. Not sure if 5.1.(1b) has this fixed. i am running 5.1.1a.
Rob Huffman Fri, 04/13/2007 - 04:41
  • Hall of Fame,
    Founding Member
Hi Sankar,
I didn't think you would be too impressed with that workaround. The "new look" Bug Toolkit doesn't show the the "First Fixed in Version" like it used to?? unless I am going blind (which is quite possible :) It does show the "First Found in Version" as;
5.1(0.9911.2)
And shows a status of Fixed, so I guess the next SR.
Take care,
Rob
thisisshanky Fri, 04/13/2007 - 15:51
Yeah i saw that. Most likely a next SR..
muhammadt Wed, 06/27/2007 - 08:24
I ran into this same issue. I'm running 5.1.1b. Thanks for the info!!!! Blew a couple of hours on it already though.
