Device discovery failure in ANM
Apr 12th, 2007
Anyone familiar with this error:
Device discovery failed: For input string:"1/0"
I am receiving it when attempting to import a new chassis into ANM. All of the credentials are correct.
dkirsch Fri, 10/12/2007 - 14:40
Number one error with ANM 1.1 installs has been not having SSHv2 configured on the Supervisor (and the subinterfaces ANM may use to reach that module). Since ANM is managing the ACE, which in turn is often managing e-commerce applications with SSL and SSH connections, not having the control interfaces at the same level of security was undersirable.
ANM 1.2 is being updated to allow the operator to start off without SSHv2, though this will be strongly discouraged for production operations.
Syed Iftekhar Ahmed Fri, 10/12/2007 - 14:44
Does ANM 1.2 supports BVI interfaces on ACEs in bridge mode for Polling?
It not there in ANM 1.1.
When is ANM 1.2 going to be available?
