Upgrading from CSA-MC ---> CSA-MC
Apr 12th, 2007
I have been tasks to upgrade our CSA-MC.
Has anyone already done this [A]
and [B] did you run into any issue that would help be before the I begin.
tsteger1 Thu, 04/12/2007 - 12:02
Yes (5.1.079).
Same server or separate server?
I did both, one on a semi-production server and the other on a VM test server.
TradeSecrets Thu, 04/12/2007 - 12:57
Hi Tom,
I was going to use the same server, I am going to read the documentation tonite.
Do you recommend using a second server. I was going to ghost the and perform the upgrade.
tsteger1 Thu, 04/12/2007 - 13:06
It depends on your environment. The recommendations in the docs are pretty good.
We are going with one server for 3500 hosts.
