CCVP course sequence
Apr 12th, 2007
would like to know if Cisco has a recommended sequence for the CCVP track
Overall Rating: 5 (1 ratings)
Pari Thiagasundaram Thu, 04/12/2007 - 12:41
You can login to the partner e-learning to look at this course map. Here it what it says:
Cisco Certified Voice Professional
The Cisco Certified Voice Professional validates a network professional's ability to implement and operate Cisco Unified Communications solutions in single site and multi-site deployments. Individuals who hold a CCVP certification can help create an IP telephony solution that is transparent, scalable, and manageable. The CCVP curriculum focuses on Cisco Unified CallManager, voice gateways and gatekeepers, switches, Unified IP Phones, and skills to secure the voice communications and ensure voice quality of service.
IMPORTANT NOTE: In an effort to better serve our valued channel partners, we have changed providers for select web-based courses. Some of the web-based versions of the courses in the following Learning Map are temporarily unavailable, but will be re-posted within the next 6 weeks. We apologize for any inconvenience you may experience during this transition.
Prerequisites: Valid CCNA certification
Recertification: CCVP certifications are valid for three years. To recertify, pass any 642 exam that is part of the professional level curriculum after 01/01/06, or pass a current CCIE written exam.
This page displays the list of learning offerings in this learning map organized into topics. To complete a learning map, you must complete the learning offerings according to the order that the topics are listed. You must complete the required learning offerings within a topic before starting the next topic. Click a learning offering to view more information about it.
Save time, money, and effort in your studies on this subject.
CCVP - Prescriptive Assessment
Take this learning offering.
Implementing Cisco Quality of Service (QOS) 2.1
Quality of Service Exam (QOS 642-642)
Take all of these learning offerings.
Must take CVOICE and CVF
Cisco Voice Over IP (CVOICE) 5.0
Cisco Voice Over IP Fundamentals (CVF)
Cisco Voice Over IP Exam (CVOICE 642-432)
IP Telephony Troubleshooting (IPTT) 4.0
IP Telephony Troubleshooting Exam (IPTT 642-425)
Take 2 of these learning offerings.
Take both the 4.1 OR both 5.0 versions
Cisco IP Telephony Part 1 (CIPT1) 4.1
Cisco IP Telephony Part 2 (CIPT2) 4.1
Implementing Cisco Unified CallManager Part 1 (CIPT1) 5.0
Implementing Cisco Unified CallManager Part 2 (CIPT2) 5.0
Take 1 of these exams
Cisco IP Telephony for Release 4.x (CIPT-4.x 642-444)
Cisco IP Telephony for Release 5.x (CIPT-5.x 642-445)
Implementing Cisco Voice Gateways and Gatekeepers (GWGK) 2.0
Take 1 of these learning offerings.
Last Day to Test Gateway Gatekeeper Exam (GWGK 642-452) is 4/26/07
Gateway Gatekeeper Exam (GWGK 642-453)
jkemejuk Thu, 04/12/2007 - 13:21
Thanks,saw that.. just seems that QoS or troubleshooting are probably more difficult, & maybe should go last, yet might be needed for all the other classes to go well.
srue Thu, 04/12/2007 - 17:21
i've done cvoice and gw/gk..currently working on qos.
There is some call mgr stuff in gw/gk but I dont think it's tested on.
QoS is'nt too bad really. After this I will be doing CIPT then IPTT.
gw/gk seems to be an 'extension' of material learned in cvoice.
good luck.
