Pre-authentication
Apr 12th, 2007
Can some body explain how the pre-authentication works? Let us I am connected to AP1 using Static WEP encryption. At the same time I see AP2(its signal strength is weak compared to AP1) to facilitate roaming. Will my laptop send authentication request to AP2 before it comes under its coverage area OR this pre-authentication stuff works only if I am using WPA?
TIA
Dmitry Halavin Fri, 04/13/2007 - 05:52
Roaming works no matter what encryption you are using. I'm not sure why you define this as "pre-authentication".
Roaming is a client decision, so some cards will perform better than others.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
