cannot PING!
Answered Question
Apr 12th, 2007
Hello
I am using a CSS11503 and I am having a problem pinging a device on the same vlan as one of the interfaces on the content switch. Interface 3/3 is connected to port 1 on switch A and has an IP address of 10.40.29.64/28. The server has an address of 10.40.29.65/28 with its gateway set to 10.40.29.64. It is connected to port 2 on switch A. Port 1 and 2 reside on vlan 103 on the switch. The interfaces on the switch and CS are up, the circuit is also up on the CS. I cannot ping the gateway from the server. My config is as follows
dndcclbtest01# sh run
!Generated on 12/04/2007 23:22:31
!Active version: sg0730106
configure
!*************************** GLOBAL ***************************
date european-date
acl enable
flow tcp-reset-vip-unavailable
cdp run
ssl associate rsakey ugwebtstssl ugwebtst
ftp-record bof-ftp 10.146.13.150 anonymous des-password
ip route 0.0.0.0 0.0.0.0 10.40.21.250 1
!************************* INTERFACE *************************
interface 3/1
bridge vlan 102
description "dndcctbdmzsw1-vlan102-10.40.29.144/28-TESTBED"
interface 3/2
bridge vlan 5
description "dndccmlsa41"
interface 3/3
description "dndcctbdmzsw1-vlan102-10.40.29.160/28-TESTBED"
phy 100Mbits-FD
bridge vlan 103
interface 3/4
description "dndundrumswa43-fa0/23-vlan1-10.152.21.0"
!************************** CIRCUIT **************************
circuit VLAN1
ip address 10.152.21.6 255.255.255.0
circuit VLAN102
ip address 10.40.29.149 255.255.255.240
circuit VLAN5
ip address 10.40.21.25 255.255.255.0
circuit VLAN103
ip address 10.40.29.164 255.255.255.240
!************************** SERVICE **************************
I must be missing something. Any ideas of what I could be doing wrong?
Thank You
Donagh
Correct Answer by joquesada about 9 years 9 months ago
Hi Donagh,
Could you attach the configuration part of the CSS related to the ACLs? Also, can you get this output: sh ip route'. Thanks!
Jose Quesada.
Overall Rating: 5 (1 ratings)
Correct Answer
joquesada Thu, 04/12/2007 - 15:11
Hi Donagh,
Jose Quesada.
donaghq_2 Mon, 04/16/2007 - 09:11
Hi Jose
When I saw the word ACL I knew immediately that I had overlooked this. I added an ACL to circuit 103 permitting everything and it is working fine. Thanks!
Donagh
