Failover over to another H.323 Gateway when all lines busy
Answered Question
Apr 12th, 2007
I have two H.323 Gateways setup, both with VIC-4FXO cards, working fine. What I'd like to do is if all 4 POTS lines on Gateway A is filled up, route the call to Gateway B and vice-versa. It's my understanding that with H.323, CallManager is unable to detect when a port or trunk-ground is full, so it must be handled through dial-peers on the Gateway itself via a higher preference.
With this config, the calls route to alternate gateway correctly and the call dials out, but drop as soon as the remote side answers. It looks like the are failing to properly negotiate a codec. Suggestions?
Gateway A:
voice service voip
h323
no h225 timeout keepalive
session transport udp
voice class codec 711
codec preference 1 g711ulaw
codec preference 2 g729r8
interface GigabitEthernet0/0
ip address 1.2.3.4 255.255.255.0
h323-gateway voip interface
h323-gateway voip h323-id VG-1
h323-gateway voip bind srcaddr 1.2.3.4
dial-peer voice 1 voip
incoming called-number .
dial-peer voice 100 pots
trunkgroup POTS
description Outbound calls
destination-pattern .T
dial-peer voice 101 voip
description Outbound Calls Overflow
preference 1
voice-class codec 711
session target ipv4:5.6.7.8
Gateway B:
voice service voip
h323
ip address 5.6.7.8 255.255.255.0
h323-gateway voip h323-id VG-2
h323-gateway voip bind srcaddr 5.6.7.8
trunkgroup POTS
preference 1
session target ipv4:1.2.3.4
Correct Answer by Aaron Harrison about 9 years 10 months ago
There are simpler ways to do this...
One is to edit the callmanager service parameters 'stop routing on user busy' and 'stop routing on unallocated number'. The gateway sends back one of these messages when it can't route the call, and by default callmanager will stop hunting at that.
Aaron
Please rate helpful posts...
Overall Rating: 3 (2 ratings)
Paolo Bevilacqua Thu, 04/12/2007 - 15:32
Hi Johnny,
when the call comes in and the GW A is full, it should redirect to the other GW, not take the call. I don't know how to configure this, perhaps with a GK and CAC, or with max-connections and preferences on the calling GW.
On the other hand, if GW A takes the call and open another call-leg to GW vi VoIP, this is effectively an IP-to-IP call that requires such an image, filename ends with _isv.
Fianlly since yuor DP 1 seems to be the incoming one, I would configure the same voice-class under it.
johnnylingo Thu, 04/12/2007 - 16:15
Well, according to the GWGK book, it is expected that overflow be configured on the Gateway, and the line "allow-connections h323 to h323" does this in my config. Calls seem to be re-routing to the backup gateway properly, but somethings's getting messed up in either the codec negotiation or routing. Both Gateways are running 12.3(11)T10
I added the following:
codec transparent
no vad
That caused the incoming calls to use G711 and no VAD (they had been using G729/w VAD), but still having the same problem. They connect, but the remote gateway never negotiates a Codec and the call drops.
Correct Answer
Aaron Harrison Fri, 04/13/2007 - 00:32
Aaron
johnnylingo Fri, 04/13/2007 - 12:27
Yep, those are the default settings in CCM 4.1 and I haven't changed them.
It seems that the book is a little off. On page 64, it says that if a PRI line on an H.323 gateway is full, CallManager will not redirect it to an alternate gateway so you must create a dial-peer with higher preference value. This doesn't appear to be true. I created a Route Group with both gateways, and when one filled up it rolled over to the next no problem.
Paolo Bevilacqua Fri, 04/13/2007 - 01:53
Yes "codec transparent" is what usually is needed in IP-to-IP calls. But you have to define it in both incoming and outgoing DPs.
Other than that I would upgrade IOS perhaps to lates 12.4 mainline.
Hope this helps, if so please rate post!
