High CPU Load on Cisco 2621 router
Apr 12th, 2007
Hi All,
My 2621 router constantly showing 90% CPU load. The show proc cpu command didn't tell me which process used lots of the cpu resources. Can I know whether there is any other way to check it?
Overall Rating: 3.5 (2 ratings)
spremkumar Thu, 04/12/2007 - 23:25
Can you post the output of show process cpu ?
you can also check out for CEF whether CEF is enabled or not.
once CEF check is over you can enable netflow and find out whether you have worms/virus in your network..
regds
Paolo Bevilacqua Fri, 04/13/2007 - 04:03
In fact the most common cause of high cpu load is abnormal traffic, so spremkumar's answer is correct, didn't deserve low rating so I have rated this to balance.
