Can't see FXS card
Apr 12th, 2007
Hi;
I have 2811 router with serial & FXS cards.
I can't find the FXS card??
R1#sh ve
Cisco IOS Software, 2800 Software (C2800NM-ADVENTERPRISEK9_IVS-M), Version 12.4)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Wed 22-Feb-06 16:37 by ccai
ROM: System Bootstrap, Version 12.4(1r) [hqluong 1r], RELEASE SOFTWARE (fc1)
ROM: Cisco IOS Software, 2800 Software (C2800NM-IPBASE-M), Version 12.3(8)T6, R)
R1 uptime is 9 minutes
System returned to ROM by reload at 21:19:18 UTC Thu Apr 12 2007
System image file is "flash:c2800nm-adventerprisek9_ivs-mz.124-4.T2.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
Cisco 2811 (revision 53.51) with 249856K/12288K bytes of memory.
Processor board ID FTX1032A2CP
2 FastEthernet interfaces
2 Serial(sync/async) interfaces
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
62720K bytes of ATA CompactFlash (Read/Write)
Overall Rating: 4 (2 ratings)
spremkumar Thu, 04/12/2007 - 20:21
As per the software advisor tool you need to have any of these ios file..
c2800nm-adventerprisek9-mz.124-11.T1
c2800nm-adventerprisek9-mz.124-7a
c2800nm-adventerprisek9-mz.123-11.XL
c2800nm-adventerprisek9-mz.123-11.T11
You can also refer the below link for more info..
http://tools.cisco.com/Support/Fusion/FusionHome.do
regds
Aaron Harrison Fri, 04/13/2007 - 01:29
You have ipbase IOS. You'll need something that supports the voice feature set... like IPVoice, SPservices, lots of others...
Aaron
Please rate helpful posts
