royalblues Thu, 04/12/2007 - 23:23
  • Green, 3000 points or more
If a router's OSPF Router ID is changed, the
router's OSPF software should be restarted before the new Router ID takes effect.
Before restarting in order to change its Router ID, the router should flush its self-originated LSAs from the routing domain or they will persist for up to MaxAge minutes.
HTH, rate if it does
Narayan
minumathur Thu, 04/12/2007 - 23:40
  • Bronze, 100 points or more
Router id play important role for selection in DR/BDR if it is broadcast envirement, Depending on your enviroment , it will play role.
-Minu
bellocarico Fri, 04/13/2007 - 03:21
Virtual-links also refer to the Router ID.
If you are to change any router ID remember to change also the virtual-link config.
