Aaron Harrison Fri, 04/13/2007 - 00:26
  • Community Spotlight Award,
    Member's Choice, May 2015
You can use time-of-day routing for this.
You will need to do the following:
1) Define time periods, and add these to a time schedule in order to define the out-of-hours (after 8pm) times.
2) Create a partition, and assign the time schedule to it. This partition will then only be 'active' after 8pm.
3) Create a translation pattern that matches all incoming numbers, and translates to the specific station you have in mind. Put this translation in the new time-scheduled partition.
See this link for info on time-of-day routing:
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_administration_guide_chapter09186a008055ccd1.html
Aaron
Please rate helpful posts...
