Routed Access Switch in a collapsed core/. distribution
We got some new 3750 switches with EIGRP stub feature. I am deploying these switches at access layer in a collapsed core/distribution network environment. Each access switch will connect to both core switches(4506), and link redudancy and high availability are consided in design. This is a layer 3 or routed access switch design, and default gateway for each VLAN will be configed in access switches. Though I have got this working in a lab environment, I would like to find a sample configuration including eigrp config on core switch and access switch. Can anyone here help me? I got a sample configure from Cisco high availability campus network design white paper, but it is a core - distribution - access switch design... my case are not exactly fit in the picture.
Any sample configuration for this routed access switch ( cisco 3750)?
hadbou Wed, 04/18/2007 - 12:45
When you are trying to deploy a hiogh availability set up using eigrp please be sure to specify the stub area which can avoid un-necessary cpu cycles for calculating the path
