1242AG to 1242AG bridge problem
Apr 13th, 2007
I have problem setting up a wireless bridge between two 1242AG APs. When i set either of them to any role different than Access Point or Root Bridge i get the interface Software status: Disabled and Hardware: Down. Can anyone tell what is it i am doing wrong ?
fmeetz Thu, 04/19/2007 - 08:37
  • Bronze, 100 points or more
With the 1240 APs you should be able to configure a point to point bridge configuration. Multipoint bridge mode is not supported on this AP. What is the IOS version that you are running on the APs?
Trending Topics - Security & Network
