7970 - Time still not right even with DST fix
Answered Question
Apr 13th, 2007
I have a cme lab setup with several types of phones 7912's, 7960's and a 7970, all the phones except the 7970 show the correct time, the 7970 is still one hour behind even though I have applied the latest firmware which had the dst fix to it, I have tried resetting the phone, reloading the router, resetting the clock and updating calendar on the router, removing telephony services from the router and reloading then running telephony services setup again, I have tried downloaded the firmware to earlier versions and back to latest version still no joy.
Anyone still having these time issues ?
12.4(11)T / CME 4.0(2)
Gui 4.0.3.1a
7970 Firmware version SCCP70.8-0-4SR2S
Correct Answer by Aaron Harrison about 10 years 2 weeks ago
Have you also set the correct time-zone under telephony-service?
If not, set that and do a create cnf-files.
Aaron
Please rate helpful posts..
Overall Rating: 5 (1 ratings)
Correct Answer
Aaron Harrison Fri, 04/13/2007 - 01:22
  • Community Spotlight Award,
    Member's Choice, May 2015
Aaron
mark_gardner Fri, 04/13/2007 - 01:43
Thanks Aaron did the trick, removed telephony services that many times during lab testing must of forgot to put the timezone back on at some point.
