Ip Phone 7920 Network Busy message
Apr 13th, 2007
Hi all, I have a problem with two Ip Phones 7920.
I have eight Access Point 1230G with the same configuratione and the same Ios version (123-8.JEA1)
When I power On Ip Phone 7920 under Access Point 1 ,It take address from Dhcp with correct registration to Callmanager.
If I am moving under Access Point 2,roaming is ok and Ip Phone works good,but if I power off and power on Ip Phone 7920 under Access Point 2,It doesn't aquire address and appear me message "network busy".
hostname ap30502
username 0013ce0ce0e3 password 7 1249554641080954292E742D60
username 0013ce0ce0e3 autocommand exit
username 0013ce3c8b94 password 7 13554743580F0179287C2A6A61
username 0013ce3c8b94 autocommand exit
username 005345000000 password 7 0256540E58525A711C1E594955
username 005345000000 autocommand exit
ip subnet-zero
ip domain name credibo.bcc.it
ip name-server 10.15.0.100
ip name-server 10.15.0.11
aaa new-model
aaa group server radius rad_eap
server 10.15.187.34 auth-port 1812 acct-port 1813
aaa group server radius rad_mac
aaa group server radius rad_acct
aaa group server radius rad_admin
aaa group server tacacs+ tac_admin
aaa group server radius rad_pmip
aaa group server radius dummy
aaa authentication login eap_methods group rad_eap
aaa authentication login mac_methods local
aaa authorization exec default local
aaa accounting network acct_methods start-stop group rad_acct
aaa session-id common
dot11 ssid xxxxxxx
vlan 1
authentication open mac-address mac_methods eap eap_methods
authentication network-eap eap_methods mac-address mac_methods
accounting acct_methods
dot11 ssid CrediVoip
vlan 2
authentication open
dot11 arp-cache
dot11 phone
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption vlan 1 key 1 size 128bit 7 xxxxxxxxxxxxxxx transmit-key
encryption vlan 1 mode ciphers wep128
encryption vlan 2 key 1 size 40bit 7 xxxxxxxxxxxxxxx transmit-key
encryption vlan 2 mode ciphers wep40
ssid xxxxxxxxx
ssid CrediVoip
short-slot-time
speed 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
power local cck 50
power client 20
channel 2422
station-role root
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no ip route-cache
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio0.2
encapsulation dot1Q 2
no ip route-cache
bridge-group 2
bridge-group 2 subscriber-loop-control
bridge-group 2 block-unknown-source
no bridge-group 2 source-learning
no bridge-group 2 unicast-flooding
bridge-group 2 spanning-disabled
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
hold-queue 160 in
interface FastEthernet0.1
no ip route-cache
bridge-group 1
interface FastEthernet0.2
no ip route-cache
bridge-group 2
interface BVI1
ip address 10.15.187.250 255.255.255.0
no ip route-cache
ip default-gateway 10.15.187.1
ip http server
ip http port 28000
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
ip radius source-interface BVI1
access-list 111 permit tcp any any neq telnet
radius-server attribute 32 include-in-access-req format %h
radius-server host 10.15.187.34 auth-port 1812 acct-port 1813 key xxxxxxxxxxxxxx
radius-server vsa send accounting
control-plane
bridge 1 route ip
Why?
Marco
migilles Fri, 04/13/2007 - 08:01
  • Cisco Employee,
Assume you are using ssid #2 (CrediVoip), which is using open authentication w/ 40 bit static wep. Only thing that could prevent a client from getting a DHCP address on one ap where it works on another would be misconfigured static WEP key or switchport is not in trunking mode. For static WEP key, can copy the key from the working AP to the non-working AP. Try another client to test DHCP using same SSID.
If you are receiving "Network Busy" when making a call, then this means the QBSS value (channel utilization) is >= 105 and no other AP to roam to.
Can see the QBSS value (CU) in the 7920 site survey. Can also do "show controller dot11radio 0 | include QBSS", which will show the QBSS # in hexadecimal format.
