dynamic virtual tunnel interface on 2821
Apr 13th, 2007
Hi all.
I have a 2821 with software 12.4(9)T1 advanced ip services.
I tried to configure a dynamic virtual tunnel interface to terminate VPN client ipsec sessions.
Reading documentation, it says to configure
interface virtual-template <number>
tunnel mode <mode>
But router does not accept "tunnel" command on interface configuration.
This feature seems supported by this software release.
Any hint?
Thank you in advance.
denis
forestalcompany Mon, 06/18/2007 - 13:45
when declaring the virtual template you need specify the mode as follows:
int virtual-template <1-200> type tunnel
then you may issue the subsequent tunnel subcommands
hope this helps!
cineca Mon, 06/18/2007 - 23:36
Hi, I forgot I had this open!
I solved the problem upgrading the image.
Documentation, at least what I found, states this feature is supported on 12.4(9)T1 but I really can't agree.
You'll need a 12.4(11)T1 or higher.
Thank you all.
