pre-shared-key characters??
Apr 13th, 2007
Can I use special characters such as ! and @ when specifying a pre-shared key for a PIX and ASA?
Patrick Iseli Sat, 04/14/2007 - 16:55
No, you cannot use special characters !
Specifies the authentication pre-shared key. Use any combination of alphanumeric characters up to 128 bytes. This pre-shared key must be identical at both peers.
mfreijser Mon, 04/16/2007 - 02:56
I recently used the @ character in a L2L tunnel between a ASA with software 7.2(1) and a 2611XM with software version 12.4, so it is definitly possible to use other characters than alphanumeric characters.
Please rate if the posts helps!
rpdinavahi Wed, 01/15/2014 - 09:23
Yes, ASA supports special characters in pre-shared-key except '?' for obvious reasons. Hope this helps.
