C3560 config register 0xF - any explanation
Apr 13th, 2007
Hi - I'm tryingto find a doc that details the config register of a C3560 switch running 12.2(25). I can see the confif reg is 0xF when I issue a sh ver, but where is an explanation of this? i.e. as per 0x2102 for routers etc..
chrihussey Sat, 04/14/2007 - 03:06
The best answer I could find is that if you check the 3560 command reference for the "sh version" command there is a note that states:
"Though visible in the show version output, the configuration register information is not supported on the switch."
