Stop LMS from sending email
Apr 13th, 2007
RME keeps sending email to the senior network admin, who doesn't like LMS to begin with. I even deleted his account from LMS, and it is still sending him email notifications. Where would I look to find his email address so I can delete it? Specifically, the email he is receiving is from a ChangeAudit Trail Purge job. At the bottom, it has this note:
NOTE: This mail is sent to the Admin as the e-mail id provided for purge mails found invalid.
I went to the Change Audit settings and put a valid email address in there, so hopefully he will stop receiving them. But where is it storing his address?
Thanks for your help.
Joe Clarke Fri, 04/13/2007 - 07:32
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Definitely look in the scheduled job properties to see if the address is configured there (i.e you may have a periodic report job running that has his email address in it). You should also check his profile in the local user setup to see if his email address is associated with his LMS username.
