Mpls label switching query
Apr 13th, 2007
I am simulating a simple scenario in the LAB. Two routers connected back to back with a framerealay PVC. Ethernet interfaces UP. Ethernet and Loop back in the routers are advertised by OSPF. OSPF and LDP router ID are the Loop back IDs
Every thing works fine but when I see in the MPLS forwarding table there is no outgoing label allocated to the ehernet interfaces in both the routers where there is a pop label for the loop back interfaces. I am expecting the routers to advertise an implicit null for all connected networks so that i get POP labels for both loopback and ethernet.
Am i going wrong any where. Please suggest.
Attached is some command o/p from both the routers
regards
Ashish
Overall Rating: 5 (1 ratings)
Harold Ritter Fri, 04/13/2007 - 09:36
  • Cisco Employee,
Ashish,
This doesn't look normal indeed. Can you attach the configuration files for both routers.
Harold Ritter Fri, 04/13/2007 - 09:53
  • Cisco Employee,
One thing that jumps to mind, are you doing label filtering? This would be accomplished with the following command:
mpls ldp advertised-label for
Hope this helps,
ashishpanda Fri, 04/13/2007 - 10:15
Ya you are right. Lable filtring was configured and unfortunately the ethernet subnets were out of range of the filter.
thanks again for your help
regards
Ashish
jiangu Sat, 04/14/2007 - 23:51
Which ethernet interfaces are you refering to? your access-list 1 on both routers does not allow label-mapping of ethernet interface's prefix to be advertised out ...
