Dmitry Halavin Fri, 04/13/2007 - 14:00
Network audit compares the configuration on the controller against the one stored in WCS database. This task creates audit reports (select a controller from configure -> controllers, and then select 'view audit reports' from the dropdown). No configuration is modified.
dewmancco Mon, 04/28/2008 - 10:15
I have the Base+Location version of WCS and it is disabled by default.
I have heard from other members that the Base only version has this enabled by default.
Since it does not make any changes, it only reports on mismatches between controllers and WCS, why would it be off by default?
I am having issues keeping my controllers in sync with the WCS, was hoping this would help.
But I guess not
Trending Topics - Security & Network
