use the same PRI for Voice and fax
Apr 13th, 2007
hello,
i have the following scenario, i have right fax server , callManager 5.0 and a voice gateway 3845 with one PRI with DID number 2795XXX, My questions is how i can configure my gateway so that PRI channels can be used for both voice and fax call ( i used MGCP between CCM and gateway and SIP between rightfax and the gateway) , another question how can i use the same DID number for both the fax and the voice incoming call, for example there is an employee have a number 2975123 so when he recieve a voice call it will go to CCM, while when we have recieve a fax it will go the right fax server like a traditional Fax machine.
thanks
kelvin.blair Sun, 04/15/2007 - 19:01
  • Silver, 250 points or more
I do not think that is possible. Generally, you have two separate numbers for that purpose. So in my opinion, I would order another block of DID's for FAXing. Use a H323 Gateway for T.38 Faxing. Create a Translation pattern for your DID's and send them to the correct destination. Here is an example of the configuration:
voice service voip
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback cisco
sip
bind control source-interface Loopback0
bind media source-interface Loopback0
fax send transmitting-subscriber $s$
fax send left-header Fax for $d$ containing $p$ pages
fax send right-header Sent $a$ $t$
voice translation-rule 1
rule 2 /^60\(98..\)/ /\1/ <----USER DID
rule 3 /^74\(81[5-9].\)/ /\1/ <---FAX DID
dial-peer voice 999020 voip
translation-profile outgoing changeNum
destination-pattern 6098..
voice-class codec 10
session protocol sipv2
session target ipv4:10.10.1.48
session transport udp
no vad
Hope this helps.
Tommer Catlin Mon, 04/16/2007 - 12:37
  • Green, 3000 points or more
im intrigued now. I know it is possible, because I have seen it before, but I have never configured it for CCM or voice gateways. It seems if the gateway was h323, it could see it was fax transmission and route accordingly and same for voice. Im going to dig around and see if Cisco does in fact do this. (instead of having seperate DIDs)
Traditional way is a seperate block for voice and one for fax.
But think about the home user. 1mb with the little gadget that sends faxes to the fax machine and voice to the phones. You would think in a big $10k router, it could do the same function.....
kelvin.blair Mon, 04/16/2007 - 13:08
If you know of way, I'm interested in finding it. Typically some of the fax machine have the ability to determine if it is a voice call or a fax call and that how it would work before.
jawwalit Tue, 04/17/2007 - 00:11
thanks all:
i think there must be an identifer on the incoming call so that can determine if the call is fax or voice, if the gateway able to do that the problem will be solve. beacuse i dont thing every customer able to buy another DID number, in addition it IS a good facility to have one number for both fAX AND VOICE
REGARDS
letmeinnn Wed, 04/18/2007 - 17:06
We have almost the same setup...
call manager 4.13 right fax hooked into a 3845 which has an incoming pri line.
the right fax server is plugged into the 3845 via a pri cross over cable so to be clear the 3845 has an incoming pri from the telco and the fax server hooked into it as another pri... at least as far as right fax thinks.
We then use a route pattern to route the did we want to the pri of the right fax server .. works great! and yes it can use any did number of our did pool.
I too wanted incoming fax and phone number to be the same but thought about how to preanswer or determine the call and thought it would be a pain .. also i think it comes down to the type of pri line you have what it supports for options.. i forget the exact option or terminology....
Hope this helps.. will read the link above to see what it is about
Cheers
