Portfast bpdu-guard vs bpdu-guard
Apr 13th, 2007
What is the difference between these two commands?
set spantree bpdu-guard mod/port {enable | disable | default}
set spantree portfast bpdu-guard mod/port {enable | disable | default}
Francois Tallet Fri, 04/13/2007 - 10:37
  • Gold, 750 points or more
None as far as I know (I'm not catos expert though). Bpduguard was initially based on portfast. It was subsequently modified to be *not* dependent on portfast (at least for its port configuration). I guess the portfast version should be deprecated.
Francois
