PEAP and 7920 Phone ?
Apr 13th, 2007
I can't seem to find any reference to the 7920 phones supporting PEAP, and I don't see an option to configure it on the 7920 so I guess the 7920 doesn't support PEAP right?
I have WCS, and 4402 controllers with 1242G AP's setup, and setup to only use PEAP.
I can't seem to get the 7920's to work, so I am guessing I need to come up with an alternate solution.
Any suggestions or ideas? Or a confirmation regarding PEAP and the 7920's would be helpful as well.
migilles Fri, 04/13/2007 - 12:39
  • Cisco Employee,
The 7920 only supports LEAP or EAP-FAST.
In 3.0 release and higher, the phone has an auto EAP mode, where it will give predecence to EAP-FAST over LEAP. Will try LEAP after EAP-FAST failure. Can also force the EAP mode in the network profile setup.
If using EAP-FAST w/ the 4400 controller, will need to increase the 802.1x timeout on the controller to at least 20 seconds vs default of 2. Do "config advanced eap request-timeout 20" via console.
Will also need to ensure that the radius server also has automatic PAC provisioning enabled if using EAP-FAST as manual provisioning is not supported.
