MGCP Fractional PRI
Answered Question
Apr 13th, 2007
How do you configure MGCP to support a fractional PRI? It keeps changing the pri-group on the controller to all 24 channels.
Correct Answer by pkentsmith about 9 years 10 months ago
Cisco DO NOT support the use of MGCP with fractional E1's. This said, there is an UNSUPPORT work around which allows you to specify in call manager which channels are available, see below: -
Within the advanced CallManager service parameters (not shown by default) there is a field called "Change B-Channel Maintenance Status 1" which can be altered to mark channels out of service. The string below will need altering depending on how many channels are in use (0 = available, 1 = unavailable). The string below is an example for 20 channels.
Change B-Channel Maintenance Status 1 as follows:
[email protected] = 0000 0000 0000 0000 0000 0111 1111 1111
PKS
Overall Rating: 5 (1 ratings)
thisisshanky Fri, 04/13/2007 - 15:51
yes read these threads.
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified%20Communications%20and%20Video&topic=IP%20Telephony&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.1ddd5a06
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified%20Communications%20and%20Video&topic=IP%20Telephony&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40%5E1%40%40.1dde27df
If using CCM-manager config, i would recommend to remove that command as Callmanager has no idea how many channels are active on the PRI. It will think that its a full PRI and change the config accordingly.
HTh
Sankar
PS: please remember to rate posts!
Correct Answer
pkentsmith Fri, 04/20/2007 - 01:37
PKS
