CallManger upgrading issue--DC Directory health check failed
Apr 13th, 2007
Hi everyone,
Now I am upgrading CCM3.3(5) to CCM4.1(3).
I run Upgrade Assisstant4.3(1) on CCMSUB, got the following message:
DC Directory Health Check: Validation failed.
( Please refer to the following message and log file. And CCMPUB validation successfully)
Could anybody see if the upgrading should proceed or not?
Thank you very much. ( please be patient to read the following log file)
got the following message in 'DC Directory Health Check_LOCAL.log' file:
04-13-2007 18:07:18.485:DCDHealthC:INFO:Calling checkDirHealth
04-13-2007 18:07:18.985:DCDHealthC:INFO:checkDirHealth returnes with -2024
04-13-2007 18:07:18.985:DCDHealthC:INFO:Detailed log location C:\dcdsrvr\log\DirUpgradeAsst.log
checked DirUpgradeAsst.log, found the following message:
'" Error occured on reg.exe
Either the PUB is down or unreachable "
04/13/2007 20:19:51.174 DCDChecker.cpp CheckDirHealth Machine is a SUB. Check for existence of passwords in PUB registry.
04/13/2007 20:19:51.236 DCDChecker.cpp checkSpecialUserPassword Starting Password check for CCMAdministrator Users
04/13/2007 20:19:51.236 DCDChecker.cpp checkSpecialUserPassword Querying the PUB registry for CCMAdministrator password C:\utils\SecurityTemplates\reg query "\\CCMPUB\HKLM\Software\Cisco Systems, Inc.\Directory Configuration\AppUsers\CCMAdministrator" /v Password > C:\dcdsrvr\log\UpgradeAssistant.txt
04/13/2007 20:19:51.377 DCDChecker.cpp checkSpecialUserPassword Reg Query for CCMAdministrator done
04/13/2007 20:19:51.393 DCDChecker.cpp checkSpecialUserPassword Searching in the temp file for the CCMAdministrator password
04/13/2007 20:19:51.393 DCDChecker.cpp checkSpecialUserPassword CCMAdministrator password found in temp file
04/13/2007 20:19:51.393 DCDChecker.cpp checkSpecialUserPassword Starting Password check for IPMASysUser Users
04/13/2007 20:19:51.393 DCDChecker.cpp checkSpecialUserPassword Querying the PUB registry for IPMASysUser password C:\utils\SecurityTemplates\reg query "\\CCMPUB\HKLM\Software\Cisco Systems, Inc.\Directory Configuration\AppUsers\IPMASysUser" /v Password > C:\dcdsrvr\log\UpgradeAssistant.txt
04/13/2007 20:19:51.424 DCDChecker.cpp checkSpecialUserPassword Reg Query for IPMASysUser done
04/13/2007 20:19:51.439 DCDChecker.cpp checkSpecialUserPassword Temp file empty. Error occured on reg.exe
04/13/2007 20:19:51.439 DCDChecker.cpp checkSpecialUserPassword Either the PUB is down or unreachable
04/13/2007 20:19:51.455 DCDChecker.cpp checkSpecialUserPassword Exiting...
04/13/2007 20:19:51.455 DCDChecker.cpp checkSpecialUserPassword Starting Password check for CCMSysUser Users
04/13/2007 20:19:51.455 DCDChecker.cpp checkSpecialUserPassword Querying the PUB registry for CCMSysUser password C:\utils\SecurityTemplates\reg query "\\CCMPUB\HKLM\Software\Cisco Systems, Inc.\Directory Configuration\AppUsers\CCMSysUser" /v Password > C:\dcdsrvr\log\UpgradeAssistant.txt
04/13/2007 20:19:51.486 DCDChecker.cpp checkSpecialUserPassword Reg Query for CCMSysUser done
04/13/2007 20:19:51.486 DCDChecker.cpp checkSpecialUserPassword Searching in the temp file for the CCMSysUser password
04/13/2007 20:19:51.486 DCDChecker.cpp checkSpecialUserPassword CCMSysUser password found in temp file
04/13/2007 20:19:51.502 DirLDAPHelper.cpp ~DirLDAPHelper Destructing DirLDAPHelper object..
04/13/2007 20:19:51.502 DirUpgConfig.cpp ~DirUpgConfig Destroying DirUpgConfig
04/13/2007 20:19:51.502 DirUpgConfig.cpp ~DirUpgConfig Unbinding LDAP
04/13/2007 20:19:51.518 DCDChecker.cpp ~DCDChecker DCDChecker Destroyed
04/13/2007 20:19:51.518 DirUpgradeAsst.cpp DllMain DLL_PROCESS_DETACH_____________________________________________________________________________
Overall Rating: 3 (1 ratings)
master001 Sat, 04/14/2007 - 05:47
Does anybody have similar experience?
Thank you for your comment and I would like to share the experience.
Howard
Rob Huffman Sat, 04/14/2007 - 09:39
Hi Howard,
You probably fix this error before you continue :) Make sure that the Subscriber servers can see the Publisher before you run the Upgrade Assistant.
This utility identifies problems that could cause the Cisco CallManager upgrade to fail. This utility does not correct the problem(s); you must perform the corrective action for the problem that the utility identifies.
Cisco strongly recommends that all servers in the cluster pass the validation before you upgrade any servers.
DC Directory HealthCheck Validation
This check occurs on the publisher database and subscriber servers.
The utility validates whether Cisco CallManager is integrated with DC Directory. This utility validates the DC Directory connection and the DC Directory configuration containers.
Interpreting the Results
The validation results display in the Upgrade Assistant Summary window. At the top of the window, a report summarizes the results for all modules and displays which modules failed, which modules produced warnings, and which modules passed. A link to the folder that contains all log files, including the Upgrade Assistant Summary report, displays also.
To identify a problem with the failed validation module, review the following information that displays in the Summary window:
The first link points to the log file that specifies the error or warning.
Click the first link and search for the error or warning; for example, ERR: or WARN: .
The second link points to the corrective action file that describes the log file error message and recommends the corrective action.
Click the second link to open the corrective action file. Search the corrective action file for the error message that is noted in the log file. Review the description and corrective action.
Caution After you correct all problems that the utility identifies, Cisco strongly recommends that you run the utility again on every server in the cluster before you begin the upgrade.
From this good doc;
http://www.cisco.com/en/US/products/sw/voicesw/ps556/prod_installation_guide09186a00803f5c59.html
Hope this helps!
Rob
mroger Mon, 04/16/2007 - 12:03
I saw a similar issue where cluster was AD integrated and the DCD services were not running on the pub.
master001 Fri, 04/27/2007 - 09:46
Sorry for the delay. I just need to follow up the post-upgrade task.
Please check the updates as follows:
I ignored the error message and continue upgrading.
After CCM-PUB/CCM-SUB finished, CCM work properly and Database replication is fine.
then I rerun the upgrade assistant again,
CCM-PUB no any errors,
CCM-SUB shows
"Database Location Setting Validation: Validation failed."
14/04/2007 23:13:58:dBConn0Chk:INFO: Accessing CCM glassHouse database
14/04/2007 23:13:58:dBConn0Chk:ERR : Database Access Failure
14/04/2007 23:13:59:dBConn0Chk:ERR : CCM Database Settings Conflict
14/04/2007 23:13:59:dBConn0Chk:ERR : Highest CCM Database=ERROR
14/04/2007 23:13:59:dBConn0Chk:ERR : DBConnection0=DSN=CiscoCallManager;
SERVER=CCMPUB;DATABASE=CCM0302;Trusted_Connection=yes
04-14-2007 23:13:59.330:dBConnChck:INFO:dBConn0Chk.exe process completed
04-14-2007 23:13:59.330:dBConnChck: ERR:Cisco Unified CallManager Database Location Setting test failed!
Today I run the upgrade assistant on CCM-SUB again,
" Validation successful !"
I would like to share this experience with you.
Has anybody some comments or similiar experience?
Thanks.
Howard
Rob Huffman Sun, 04/29/2007 - 08:35
Hi Howard,
Its good to see that you are moving forward here, great job! My guess is that you were doing these checks with the Sub isolated from the Pub, so this would be expected. Once the 2 boxes could see each other and sync'd up again the Validation was successful.
Rob
