501 PPTP random drops
Apr 13th, 2007
Here is a DSL configuration which a client inside has a PPTP connection to an outside address. The PPTP session drops serveral times a day at random times and I've been trying to figure this out. Can anyone please help. Here is my config:
PIX Version 6.3(5)
interface ethernet0 auto
interface ethernet1 100full
nameif ethernet0 outside security0
nameif ethernet1 inside security100
clock timezone PST -8
clock summer-time PDT recurring 2 Sun Mar 2:00 1 Sun Nov 2:00
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol pptp 1723
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
names
access-list VPN permit ip 172.16.1.0 255.255.255.0 172.16.2.0 255.255.255.0
pager lines 24
logging on
logging buffered warnings
mtu outside 1500
mtu inside 1500
ip address outside pppoe setroute
ip address inside 172.16.1.1 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
ip local pool ippool 172.16.2.51-172.16.2.100 mask 255.255.255.0
pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list VPN
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout sip-disconnect 0:02:00 sip-invite 0:03:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server TACACS+ max-failed-attempts 3
aaa-server TACACS+ deadtime 10
aaa-server RADIUS protocol radius
aaa-server RADIUS max-failed-attempts 3
aaa-server RADIUS deadtime 10
aaa-server LOCAL protocol local
ntp server 164.67.62.194 source outside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
sysopt connection permit-ipsec
crypto ipsec transform-set myset esp-3des esp-md5-hmac
crypto dynamic-map dynmap 10 set transform-set myset
crypto map mymap 10 ipsec-isakmp dynamic dynmap
crypto map mymap client authentication LOCAL
crypto map mymap interface outside
isakmp enable outside
isakmp identity address
isakmp nat-traversal 20
isakmp policy 10 authentication pre-share
isakmp policy 10 encryption 3des
isakmp policy 10 hash md5
isakmp policy 10 group 2
isakmp policy 10 lifetime 28800
vpngroup grpname address-pool ippool
vpngroup grpname split-tunnel VPN
vpngroup grpname idle-time 1200
vpngroup grpname password *
telnet 0.0.0.0 0.0.0.0 inside
telnet timeout 15
ssh 0.0.0.0 0.0.0.0 outside
ssh timeout 10
console timeout 15
vpdn group ABC request dialout pppoe
vpdn group ABC localname [email protected]
vpdn group ABC ppp authentication pap
vpdn username [email protected] password *
dhcpd address 172.16.1.101-172.16.1.200 inside
dhcpd lease 604800
dhcpd ping_timeout 750
dhcpd enable inside
terminal width 80
Thanks in advance.
