Busy and no answer support for CCME B-ACD
Apr 14th, 2007
Having realized that dial by extension would not return to the script if busy or no answer, I didn't liked that very much, and have added the code, now callers that gets a busy extension are sent again to menu choices and their call is not dropped.
I've tested a little and works fine even on cme 3.2, hope someone can benefit from it.
Attached the diffs or contact me.
<i>Hope this helps, if so rate post!</>
