paolo bevilacqua Sun, 04/15/2007 - 01:24
  • Hall of Fame,
    Founding Member
You need:
voice register global
authenticate realm
voice register dn 17
number 2017
voice register pool 17
id mac 0000.0000.0000
number 1 dn 17
dtmf-relay rtp-nte
username password
Set username, password and realm in the phone. The phone must attempt to register the same number as in "voice register dn".
Hope this helps, if so please rate post!
sandeep pokhriyal Sun, 04/15/2007 - 05:30
hi,i hae got one X-lite phone.
this is what i confiugred .
max-dn 192
max-pool 48
authenticate realm cisco
voice register dn 100
number 1000
voice register pool 48
id mac 000A.E434.5C00
number 1 dn 100
dtmf-relay rtp-nte
and what is this username and password ??in which command promt u have to enter this as router is not accepting it except at config mode
paolo bevilacqua Sun, 04/15/2007 - 08:00
  • Hall of Fame,
    Founding Member
Which IOS version are you using?
Username and password are entered in "voice register pool" mode. The mac you enter does not matter, you can put anything.
sandeep pokhriyal Sun, 04/15/2007 - 11:48
m having 4.1 ccme and the ios version is
c2800nm-advipservicesk9-mz.124-11.XJ2.bin
paolo bevilacqua Sun, 04/15/2007 - 12:08
  • Hall of Fame,
    Founding Member
So username is supported in your IOS. I suggest to configure username same as registering number in the (soft)phone, to simplify the configuration.
sandeep pokhriyal Mon, 04/16/2007 - 04:25
hi now i made all parameters same.
max-dn 192
max-pool 48
number 100
id mac 000A.E434.5CD0
number 1 dn 100
dtmf-relay rtp-nte
also when i am giving username 100 password 100
its coming out of "voice-register-pool" mode.
without giving any error and goin to config mode.
i am using x-lite sip softphone as it is free to download.
paolo bevilacqua Mon, 04/16/2007 - 05:09
  • Hall of Fame,
    Founding Member
This is very strange. Under "voice register pool", with the same IOS, I can configure:
ccme(config-register-pool)#?
voice register pool configuration commands:
after-hour After-hours call blocking
alias Associate alias pattern
application Define application
blf-speed-dial Define BLF speed dial ip-phone button
call-waiting Enable the call-waiting option for SIP phone
check-version send check-version msg to TNP phone
codec select the preferred codec to be used for SIP phone
cor Class of Restriction on dial-peer for this dn
description Define description for SIP phone
dialplan Associate a dialplan
dnd Turn on DND feature
dtmf-relay Transport DTMF digits across IP link
exit Exit from voice register pool configuration mode
fastdial Define ip-phone fastdial number
id define phone or device id
incoming Incoming called number
keep-conference Enable the conference when initiator drop-off
no Negate a command or set its defaults
number Define E.164 telephone number
preference Configure the preference for the voip dial-peers to be
created
presence enable call list feature
proxy Define SIP proxy for this pool
reset reset SIP phone
restart restart the SIP phone
session-transport Define the transport type to TNP phone
speed-dial Define ip-phone speed-dial number
template template tag used for SIP phone
type Define sip-phone type
username define username for authenticate
vad Enable vad on dial-peer and phone
voice-class Set voice class parameters
I'm using an IP-to-IP GW images, however it should not make any difference. Also other people can register 3rd party phone to CCME.
We should find out why "username" is not valid under "voice register pool" for you.
sandeep pokhriyal Mon, 04/16/2007 - 12:09
even i changed the ios to different version
still i am only getting half of these options.
dont kn yy.
paolo bevilacqua Mon, 04/16/2007 - 13:07
  • Hall of Fame,
    Founding Member
Strange. Do you have ?
voice service voip
allow-connections sip to sip
sip
registrar server
sandeep pokhriyal Mon, 04/16/2007 - 23:12
Router(config)#voice register pool 17
Router(config-register-pool)#?
call-forward Define E.164 telephone number for call forward
created
translate-outgoing Translation rule
and i have changed the ios also to this one:-
c2800nm-advipservicesk9-mz.124-11.T1.bin
still m not able to get commands as posted by you.
paolo bevilacqua Tue, 04/17/2007 - 04:22
  • Hall of Fame,
    Founding Member
this reduced set of commands is the one typical of older IOS versions. It is like the router is not actually running the images you mentioned. Can you do a "show version", "show flash" please ?
sandeep pokhriyal Tue, 04/17/2007 - 12:38
hi,
this is the router ios i have got from show version.
also its the only ios in router otherwise it wont comeup.
paolo bevilacqua Tue, 04/17/2007 - 13:19
  • Hall of Fame,
    Founding Member
Can you don show telephony-service and paste it here ? I don't know how to explain this behavoir of not having the features running the correct image. Can you you check if you have any boot statement in config, perhaps an old image is somewhat booted.
sandeep pokhriyal Tue, 04/17/2007 - 22:49
hi,
the show telephony-service is showing version 4.1
also i changed the ios to latest what i found on cisco. also i run this command.
"boot system flash" for this image.
these are the files in flash.
Router#sh flas
2 1826 Aug 15 2006 23:05:30 +00:00 sdmconfig-28xx.cfg
3 4734464 Aug 15 2006 23:05:56 +00:00 sdm.tar
4 833024 Aug 15 2006 23:06:14 +00:00 es.tar
5 1052160 Aug 15 2006 23:06:36 +00:00 common.tar
6 1038 Aug 15 2006 23:06:52 +00:00 home.shtml
7 102400 Aug 15 2006 23:07:10 +00:00 home.tar
8 491213 Aug 15 2006 23:07:30 +00:00 128MB.sdf
9 1684577 Aug 15 2006 23:07:58 +00:00 securedesktop-ios-3.1.1.27-k9.pkg
10 398305 Aug 15 2006 23:08:20 +00:00 sslclient-win-1.1.0.154.pkg
11 36282900 Apr 17 2007 08:08:28 +00:00 c2800nm-advipservicesk9-mz.124-13a.bi
n
sandeep pokhriyal Wed, 04/18/2007 - 01:23
can u tell me which ios you are running or u can suggest me some. i will try to upload new image.
paolo bevilacqua Wed, 04/18/2007 - 02:30
  • Hall of Fame,
    Founding Member
There is no 12.4T image in the flash. Insteas, there is a 12.4 non T image, that when booted would produce the results you are saying.
If there is one and only image in the flash, it will boot without need for "boot commands". Also if you cold just capture the whole boot process from console that would help.
sandeep pokhriyal Wed, 04/18/2007 - 03:27
hi,
as i mentioned i changed software again ..
if u check above mail then u will find tht i was using the image with "t".
with same result.
let me check with a newer release with 124t also and i will get back to you.
thx
a-zucchini Thu, 04/19/2007 - 01:36
with this version "c2801-spservicesk9-mz.124-11.T1.bin" it's working properly
a-zucchini Wed, 04/18/2007 - 00:29
hi
I'm trying to register a 3th party sip phone to may cme ver 4.1 ios ver "c2801-adventerprisek9-mz.124-13a.bin", but there isn't "voice register...." command can you help me ?
sandeep pokhriyal Wed, 04/18/2007 - 01:22
hi,
we are also troubleshooting the same issue.
will get back to you once done also u can check our posts.
paolo bevilacqua Wed, 04/18/2007 - 02:32
  • Hall of Fame,
    Founding Member
You need a more recent version of 12.4T, note that with the IOS you mentioned you do not have CME 4.1 but more likely 3.4.
