AAA Authentication & Accounting using Tacacs+ Commands order
Answered Question
Apr 14th, 2007
In the cisco Remote Access Companion guide book page 394 we have got this configuration lines :
RTA(config)#tacacs-server host 192.168.0.11
RTA(config)#tacacs-server host 192.168.0.12
RTA(config)#tacacs-server key topsecret
RTA(config)#aaa new-model
RTA(config)#aaa authentication login default group tacacs+
If I want to add to the configuration above ,the command below :
RTA(config)#aaa accounting connection defult stop-start tacacs+
Is it necessary for the above lines to be in a specific order when I configure RTA ?
Correct Answer by Craig Balfour about 9 years 10 months ago
No, the order in which you enter the commands does not matter.
Overall Rating: 5 (1 ratings)
Correct Answer
Craig Balfour Sun, 04/15/2007 - 04:12
mbroberson1 Thu, 05/03/2007 - 09:40
The first tacacs server listed will the first tacacs server queried. I would make may primary ACS the first listed. Everything else looks good.
