How to tune the ring timout timer in call manager 4.1?
Apr 15th, 2007
Hi All,
By default, if user A (IP phone) calls user B (IP Phone), if user B does not answer the call and user A does not change back to on hook, the phone of user B just keep ringing. How to set the timer to cut the call? in CME, just the "timeout" command is needed but I can not find a parameter in CM.
Thanks!
Best Regards,
Teru Lei
Chris Deren Sun, 04/15/2007 - 07:02
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
The Ring No Answer Duration service parameter should take care of it, this global parameter can be overriten at the line level with the same field.
HTH,
Chris
mchandak Sun, 04/15/2007 - 08:10
  • Gold, 750 points or more
And to add to the suggestion made by Chris, with CM 4.x onwards, you can configure it on individual phones as well and specify how long you want the phone to ring. Each ring is around 4 secs, so if u want the phone to ring for 4 rings, then this timer should be sent to 16
