Richard Burts Sun, 04/15/2007 - 09:30
Gil
The question in the header of your message asks why the dialer stays up and I have an answer to that. You then state a requirement for the dialer to go down when the atm goes down. I do not have an authoritative answer for that.
The dialer stays up when the underlying media goes down so that the dialer will still appear to be available. You want the dialer to still appear to be available so that the route to the subnet of this interface will remain in the routing table (so that things like floating static routes can work).
I have not used it for this and do not know for sure whether it would work for you or not, but you might look into Enhanced Object Tracking as a way to force the interface down if connectivity through the underlying media is lost.
Rick
