asa webvpn
Apr 15th, 2007
I am not that familiar with webvpn. Is there a way to have person authenticate and then have access to resources such as remote desktop, telnet, etc once the authentication is complete?
Overall Rating: 3 (1 ratings)
Danilo Dy Tue, 04/17/2007 - 06:33
I use and configure ASA SSL VPN/WebVPN.
WebVPN is clientless SSL VPN, allows remote client to use SSL-enabled web browser to access http- or https-enabled web servers on the corporate LAN. Access is also available to browse for Windows files with the Common Internet File System (CIFS). A good example of http access is the Outlook Web Access (OWA) client.
You need full SSL VPN client to access RDC, Telnet, FTP, etc..
zhenningx Wed, 04/18/2007 - 05:30
You can use the webvpn to access resources(RDP, telnet etc) through the vpn portal interface, no need to have SSL VPN Client. You have to enable and configure port forwarding.
dave96chi Mon, 04/23/2007 - 01:50
Do you have a sample config? Using RDP without having the SLL VPN Client.
