Could someone please check my COR config?
Apr 15th, 2007
Gurus,
Could you please examine my COR config below for problems, on CME 4.0. I only need to block incoming (outgoing to PSTN) Long distnace, 411, 1900, basically any toll. I really have no idea how to set this up properly, just putting the config together from various sources. I really need this to work.
Also, could someone post an example of the actual ephone config, with the COR applied to it?
Thanks for your feedback.
-Michael
dial-peer cor custom
name 911
name 1800
name local-call
name ld-call
name 411
name int-call
name 1900
dial-peer cor list call1800
member 1800
dial-peer cor list call911
member 911
dial-peer cor list callint
member int-call
dial-peer cor list callld
member ld-call
dial-peer cor list call411
member 411
dial-peer cor list localonly
member 911
member 1800
member local-call
dial-peer cor list call1900
member 1900
dial-peer cor list LongDistance
member 911
member 1800
member local-call
member ld-call
dial-peer cor list calllocal
member local-call
dial-peer voice 20 pots
corlist outgoing call911
destination-pattern 911
no digit-strip
port 0/0/0:23
dial-peer voice 21 pots
corlist outgoing call1800
destination-pattern 91800.......
port 0/0/0:23
forward-digits 11
dial-peer voice 22 pots
corlist outgoing calllocal
destination-pattern 9[2-9]......
port 0/0/0:23
forward-digits 7
dial-peer voice 23 pots
corlist outgoing callld
destination-pattern 91..........
port 0/0/0:23
forward-digits 11
dial-peer voice 24 pots
corlist outgoing callint
destination-pattern 9011.T
port 0/0/0:23
prefix 011
Overall Rating: 1 (1 ratings)
Paolo Bevilacqua Sun, 04/15/2007 - 12:03
  • Hall of Fame,
    Founding Member
Hi, you config appears almost correct, but I can see that the international is not well defined yet.
Now just apply the desired COR to the user:
ephone-dn
corlist outgoing
The thing is that COR is N-ways associative, that requires to full define membership in all the COR DPs, although you can somewhat simplify with few techniques. For example, because most likely 911 is always allowed, you can remove that corlist altogether. And in many cases, a simple 'all allowed' on certain ephone-dn will be enough, remember that if no COR, the call succeeds.
Another problem with COR is that cannot be overridden. So when the boss is at an employee's desk, he/she wants to make a certain type of call, still he/she cannot.
This is nuisance and typically leads to customer requesting instead PIN access for certain calls, luckily this can be done too.
Hope this helps, if so please rate post!
