ASA - Softpphone thro SSL vpn
Apr 15th, 2007
I have problem with softphone ,when am using ssl vpn (ASA).i got one way communication .Is there ant possible solution for solve the issue ? anybody facing the problem previously ?
Am using nortel softphone.when am connect thro ssl vpn ,i can reached voice server .
when am using RAVPN thro Concentrator ...its working fine
IS there any solutions ?
Patrick.Beaven Fri, 04/20/2007 - 07:22
If its not an acl problem, look at what ports the softphone is using. Make sure that there being either redirected either Loopback or portforwarded.
