VRF-Lite issue with ip summary-routes
dlongworth
Hi All,
I'm relatively new to VRF-Lite and need some help please.
I've implemented a vrf-lite config, edited config below contains the interesting bits.
Does anyone know if there are any issues between using 'rd1:1' with 'router eigrp 1', that may affect propogation of CUST_A's eigrp summary-routes?
CUST_B is distributing summary-routes successfully but CUST_A cannot (Both have routers directly connected to this router). There is a summary-route '172.17.64.0/18' on the neighbouring router. All other routes are fine, except any summary-routes. The FD for the CUST_A summary-route is seen as 4294967295 & hence 'Inaccessible'.
The only thing I can think of is if there is a reason, which I'm unaware of, that I shouldn't be using 'router eigrp 1' and rd1:1 for a customer. But I can't find anything that states so.
Cheers for any help
ip vrf CUST_A
rd 1:1
ip vrf CUST_B
rd 10:1
router eigrp 1
no auto-summary
address-family ipv4 vrf CUST_B
network 10.0.0.0 0.0.0.7
network 10.0.0.16 0.0.0.7
network 192.168.253.0
no auto-summary
autonomous-system 10
exit-address-family
address-family ipv4 vrf CUST_A
network 10.91.0.0 0.0.0.3
network 151.178.254.208 0.0.0.3
no auto-summary
autonomous-system 1
exit-address-family
You get the same behavior with or without VRF. If the prefix cannot be installed in the RIB, EIGRP sets the FD to inaccessible and therefore doesn't propagate it to any neighbors.
To fix the issue just remove the static from the specific VRF.
Hope this helps,
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
6 Replies 6
Harold Ritter
David,
The FD being set to 4294967295 usually means that this route is already installed in the RIB from another source having a better admin distance. See if this is the case for 172.17.64.0/18 in VRF CUST_A.
Hope this helps,
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
I've had to insert a static route temporarily, but I've never seen an FD of this magnitude. All other routers (although non-vrf) show an FD=3328 for the same summary-route originating from the same router.
The FD is simply set to inaccessible (0xffffffff = 4294967295) and as I mentioned before, probably because the specific prefix was already installed in the RIB (VRF CUST_A) from another source with a lower admin distance. Have you been able to verify this?
Hope this helps,
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
The only other possible source is the locally configured static route. But I've never seen this before.
I've had routers with statics and eigrp routes; obviously the routing-table prefers the static but the eigrp FD was always calculated and remained around in the thousands, never set like this.
Is this something specific to VRF?
DC-VRF-One#sh ip ro vrf CUST_A 172.17.64.0
Routing entry for 172.17.64.0/18
Known via "static", distance 1, metric 0
Routing Descriptor Blocks:
* 151.178.254.210
Route metric is 0, traffic share count is 1
DC-VRF-One#sh ip ro vrf CUST_A static
172.17.0.0/18 is subnetted, 3 subnets
S 172.17.128.0 [1/0] via 151.178.254.217
S 172.17.192.0 [1/0] via 151.178.254.210
S 172.17.64.0 [1/0] via 151.178.254.210
DC-VRF-One#sh ip eigrp vrf CUST_A top 172.17.64.0 255.255.192.0
IP-EIGRP (AS 1): Topology entry for 172.17.64.0/18
State is Passive, Query origin flag is 1, 0 Successor(s), FD is 4294967295
151.178.254.210 (TenGigabitEthernet1/4), from 151.178.254.210, Send flag is 0x0
Composite metric is (3840/3584), Route is Internal
Vector metric:
Minimum bandwidth is 1000000 Kbit
Total delay is 50 microseconds
Reliability is 255/255
Load is 1/255
Minimum MTU is 1500
Hop count is 4
DC-VRF-One#
Hope this helps,
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
Ah! I perceive my misunderstanding. Bit of a wild goose chase there.
Being new to VRF-lite, I thought it was my VRF-Lite config that was doing something to EIGRP.
A case of over-analyzing my problem; skipping the fundamentals.
Thank you for your assistance, it was very helpful.
