REAP Mode for AP
Apr 16th, 2007
May I know if I try to access local resources in my LAN will it travel through the network controller in the remote site?
E.g.:
PC -- Remote AP -- Router -- Router -- Network Controller
Is the web authentication using RADIUS works in REAP case?
Thanks.
Overall Rating: 3 (1 ratings)
ankbhasi Mon, 04/16/2007 - 08:08
  • Cisco Employee,
Hi Friend,
If you are talking on AP1000 series then no WEB AUTH will not work as REAP AP always do local switching even when it is in connected status.
IF you have LWAPP converted APs they work as HREAP and WEB auth will work only when it is in connected satus but when it is in standalone status i.e when controller is unreachable state already authenticated clients will keep passing traffic but new clients will not be able to associate.
Ankur
*Pls rate all helpfull post
wooiboontan Mon, 04/16/2007 - 17:10
Thanks for reply. What about data flow? If I try to access to LAN server and the data will route to remote network controller or just the AP and switch locally?
ankbhasi Mon, 04/16/2007 - 21:44
  • Cisco Employee,
Hi Friend,
The data will be switched locally by AP and will not hit network controller.
Ankur
bongu Mon, 07/02/2007 - 01:12
if i may make an additional query on this train of thought...
if the data will be switched locally, HREAP...then VPN connections would also be switched locally, correct? referring to the line diagram below, VPN connections will be terminated locally (not get on the LWAPP tunnel)
PC - LAP - FW/VPN Concentrator - L3 cloud - WLC
is there any particular concern on this?
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
