04-16-2007 02:05 AM - edited 03-05-2019 03:28 PM
Is there a place on cisco.com where I can find info about switch IOS's. The main "IOS" link only references the router images.
Thanks!
Solved! Go to Solution.
04-16-2007 02:31 AM
Chris,
You can go to software centre and chose switch software (CCO required)
http://www.cisco.com/public/sw-center/
HTH, rate if it does
Narayan
