remote access vpn between ios rtr and vpn client using certs
Apr 16th, 2007
i was trying to setup remote access vpn between ios router 12.3 and vpn client 4.x, using microsoft ca.. but i was unable to connect with vpn client .. i dnt knw where i m going wrong .. my rtr cfg is as follows
version 12.3
service timestamps debug uptime
service timestamps log uptime
hostname Central_site
aaa new-model
aaa authentication login vpn_auth group tacacs+
aaa authentication login LOCAL local
aaa authorization network LOCAL local
aaa authorization network vpn_auth group tacacs+
aaa session-id common
ip subnet-zero
ip tcp synwait-time 5
no ip domain lookup
ip domain name cisco.com
ip audit notify log
ip audit po max-events 100
crypto ca trustpoint ca_serv
enrollment mode ra
enrollment url http://10.1.1.3:80/certsrv/mscep/mscep.dll
usage ike
serial-number
fqdn none
subject-name cn=vpnclient,OU=guest_group
rsakeypair rsakey
crypto ca certificate chain ca_serv
certificate 6146C131000000000008
30820320 308202CA A0030201 02020A61 46C13100 00000000 08300D06 092A8648
92
{cut for space}
quit
certificate ca 72E76FC6C80A07BE4E6B545DE8376B3F
{cut for space}
quit
crypto isakmp policy 10
encr 3des
group 5
crypto isakmp identity dn
crypto isakmp client configuration group guest_group
dns 10.1.1.3
pool vpnpool
acl 100
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto dynamic-map dynmap 10
set transform-set ESP-3DES-MD5
crypto map vpn_map client authentication list LOCAL
crypto map vpn_map isakmp authorization list LOCAL
crypto map vpn_map client configuration address initiate
crypto map vpn_map client configuration address respond
crypto map vpn_map 10 ipsec-isakmp dynamic dynmap
interface FastEthernet0/0
ip address 10.1.1.1 255.255.255.0
duplex auto
speed auto
interface Serial0/0
no ip address
encapsulation frame-relay
interface Serial0/0.1 point-to-point
ip address 172.31.235.21 255.255.255.252
frame-relay interface-dlci 100
crypto map vpn_map
ip local pool vpnpool 192.168.1.100 192.168.1.200
no ip http server
no ip http secure-server
ip classless
ip route 0.0.0.0 0.0.0.0 Serial0/0.1
access-list 100 permit ip 192.168.1.0 0.0.0.255 any
dial-peer cor custom
end
i generated a certificate for vpnclient having OU=guest_group.. below is the debug message for crypto isakmp sa
01:25:44: ISAKMP (0:1): UNITY's identity FQDN but no group info
01:25:44: ISAKMP (0:1): peer matches *none* of the profiles
01:25:44: ISAKMP (0:1): processing CERT payload. message ID = 0
01:25:44: ISAKMP (0:1): processing a CT_X509_SIGNATURE cert
01:25:44: ISAKMP (0:1): peer's pubkey isn't cached
01:25:44: ISAKMP (0:1): Input = IKE_MESG_INTERNAL, IKE_PROCESS_MAIN_MODE
01:25:44: ISAKMP (0:1): Old State = IKE_R_MM5 New State = IKE_R_MM5
01:25:44: ISAKMP (0:1): sending packet to 10.2.1.3 my_port 500 peer_port 500 (R)
MM_KEY_EXCH
01:25:44: ISAKMP (0:1): Input = IKE_MESG_INTERNAL, IKE_PROCESS_ERROR
01:25:44: ISAKMP (0:1): Old State = IKE_R_MM5 New State = IKE_R_MM4
01:25:44: ISAKMP (0:1): received packet from 10.2.1.3 dport 500 sport 500 Global
(R) MM_KEY_EXCH
01:25:44: ISAKMP: set new node 1338741477 to CONF_XAUTH
01:25:44: ISAKMP (0:1): processing HASH payload. message ID = 1338741477
01:25:44: ISAKMP (0:1): processing NOTIFY INVALID_PAYLOAD protocol 1
spi 0, message ID = 1338741477, sa = 82F624C8
01:25:44: ISAKMP (0:1): peer does not do paranoid keepalives.
01:25:44: ISAKMP (0:1): deleting SA reason "recevied fatal informational" state
(R) MM_KEY_EXCH (peer 10.2.1.3) input queue 0
01:25:44: ISAKMP (0:1): deleting node 1338741477 error FALSE reason "information
al (in) state 1"
diptanshusingh Sat, 04/21/2007 - 23:32
HI , i resolved it actually i was trying at ios 12.3 , but the feature is supported from 12.4..
