VPN Client Connects but no connectivity | SBS2003 Std Problem?
Apr 16th, 2007
Hi - This may be a common problem, I'm new to VPNs so please be kind!
I have posted this elsewhere, but believe this to be a better place for my post - if an Admin could delete my post in the infrastructure forum that would be great.
We have a small network with a server running SBS2003 Std with only a basic firewall - it does not run ISA server.
The configuration is:-
Internet <---> Router/Modem <---> External NIC (10.0.0.x) <---> Server <---> Internal NIC (192.168.0.x) <---> Internal Network.
The problem is that our internal SBS clients are unable to use the Cisco VPN client to access resources on an external server.
The VPN client connects but with no connectivity, it fails the ping test. I have tried adjusting the network metric so that VPN is 1 and LAN connection is 100 on clients but no luck.
I have attached ipconfig and route print output from the client machine.
Can some help? We really need access to the VPN.
FTR, if we bypass the server the VPN works perfectly.
Best - James
Anonymous (not verified) Fri, 04/20/2007 - 09:40
VPN Client Not Supported on Windows NT Servers , The VPN Client is not supported on any Windows NT server version (including Windows 2000 and Windows .NET/2003 and SBS servers).
Only Windows NT 4.0 Workstation and Windows 2000 Workstation are the supported platforms.
chekc this link information about the supported operating systems by the VPN Software Client.
http://www.cisco.com/univercd/cc/td/doc/product/vpn/client/rel404/404clnt.htm#wp1253937
