Inter vlan routing
Apr 16th, 2007
I'm using 6509 switch and created nearly 20 vlan's but all the vlan's are able to access each other. How do i block this without using access-list ?
Please help me is there any other option.Please find the show version of my switch.
IOS (tm) s72033_rp Software (s72033_rp-IPSERVICESK9_WAN-M), Version 12.2(18)SXF3, RELEASE SOFTWARE (fc1)
Technical Support:
Copyright (c) 1986-2006 by cisco Systems, Inc.
Compiled Tue 14-Feb-06 18:08 by kehsiao
Image text-base: 0x40101040, data-base: 0x42DA0000
ROM: System Bootstrap, Version 12.2(17r)S2, RELEASE SOFTWARE (fc1)
BOOTLDR: s72033_rp Software (s72033_rp-IPSERVICESK9_WAN-M), Version 12.2(18)SXF3, RELEASE SOFTWARE (fc1)
Campus-core-sw1 uptime is 40 weeks, 1 day, 1 hour, 5 minutes
Time since Campus-core-sw1 switched to active is 40 weeks, 1 day, 1 hour, 4 minutes
System returned to ROM by power cycle (SP by power on)
System restarted at 18:01:00 IST Sun Jul 9 2006
System image file is "disk0:s72033-ipservicesk9_wan-mz.122-18.SXF3.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
cisco WS-C6509-E (R7000) processor (revision 1.2) with 458720K/65536K bytes of memory.
Processor board ID SMC1008007R
SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache
Last reset from power-on
SuperLAT software (copyright 1990 by Meridian Technology Corp).
X.25 software, Version 3.0.0.
Bridging software.
TN3270 Emulation software.
49 Virtual Ethernet/IEEE 802.3 interfaces
96 FastEthernet/IEEE 802.3 interfaces
36 Gigabit Ethernet/IEEE 802.3 interfaces
1917K bytes of non-volatile configuration memory.
8192K bytes of packet buffer memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
minumathur Mon, 04/16/2007 - 06:04
disable ip routing on switch and disable rip/ospf etc on switch, configure switch as L2 Vlan
I hope this will help you out, please rate this post.
udayashankarsg Mon, 04/16/2007 - 07:20
These vlan's are advertised in WAN. Will there be any effect in WAN advertisement.Please find the vlan configuration and help me how can i disable ip routing.
description " vlan37 @ Campus "
ip address
no ip redirects
ip route-cache flow
Francis Garcia Wed, 04/13/2011 - 17:09
You can implement vrf-lite, in such way that no vlan can comunicate with each other, this is a great method and the traffic is totally isolated without needing vlan acl's or IP acls.
The configuration looks like this,
ip vrf vlan3
rd 1:3
ip vrf vlan4
rd 1:4
interface vlan 3
ip vrf forwarding vlan3
ip address x.x.x.x
interface vlan 4
ip vrf forwading vlan4
ip address x.x.x.x
This is the method that I use for isolating the voice vlan traffic from other vlans and It really looks more elegant.
Christian Capitan Wed, 04/13/2011 - 17:54
If you want a base config let me know. I will say looking at the config will not make much sense unless you read the Cisco doc, so I recommend reading it.
