ip tacacs source-interface : can vlan1 be used?
Apr 16th, 2007
Hi All,
I have a distribution box with multiple SVIs. In order to hop from one box to another box, I have added an ACL for the vty lines. The ACL has
access-list 10 permit 10.1.0.0 0.0.255.255
access-list 10 deny any log
But I do not have loopback interface configured on all devices yet. I tried using "ip tacacs source-interface vlan1" and "ip ssh source-interface vlan1" and it did not work. Does it only work with loopbacks?
walleyewiz Mon, 04/16/2007 - 08:16
yes, i have used it on many switches.
From a current 3750:
ip tacacs source-interface Vlan1
Richard Burts Mon, 04/16/2007 - 08:32
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
MEENA
I agree with Brad that the source-interface command is not restricted to loopback interfaces. It will use whatever interface you specify (as long as that interface is available). I have used the source-interface command with a variety of interfaces and it works. If you tried it before and it did not work then there must be some other explanation of the problem (perhaps the server not configured to match the address that you specified, perhaps a key mismatch, perhaps something else).
Rick
John Lukes Fri, 12/09/2016 - 14:09
Check the configuration for "vlan1" and post it here.
Is the name "vlan1" or "Vlan1"
