vpn 3002
Apr 16th, 2007
Hi All;
I have a vpn3002 concentrator that i'm trying to configure access to using group authentication. i created a digital ceertificate to be used by the group and created the SA and IKE proposals, however when i try to connect using the cisco client i get an error that the client auth mode differs from the group ike auth mode. if i go in and alter it to use no certificate then i get and error that the connection requires xAuth but the proposal does not support it. any one have any ideas what i'm missing, i figure it's something small but right now i'm honestly not seeing it. thnaks in advance.
s.jankowski Fri, 04/20/2007 - 06:19
try this workaround
Configuration | User Management | Groups | Modify xxx > Ipsec tab >change from ESP/IKE-3DES-MD5 to ESP-3DES-MD5
