how to get cisco CIP card's cipCardEntryIndex by snmp?
Apr 16th, 2007
not-accessible
Size list: 1: 0..2147483647
Description: Index into cardTable (not physical chassis
slot number, matches cisco chassis MIB cardindex)
any workaround for this?
Joe Clarke Mon, 04/16/2007 - 08:35
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
You need to read this value from the left-hand side of the OID name/value pair. So, if you do a GETNEXT operation on cipCardEntry, the last element returned in the resulting varbind will be the index.
haoz Sun, 04/22/2007 - 06:19
Thanks, but the format of indexes seems different from those shown in cmd 'show extended channel x/y statistics' as
csna path xxyy, while by snmp polling the result is x.y.z.
If we need the xxyy directly from snmpget, any suggestion?
Joe Clarke Sun, 04/22/2007 - 07:01
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
The cipCardEntryIndex is not supposed to be the same as the actual physical slot number. Instead, it is an index into the OLD-CISCO-CHASSIS-MIB, and will match cardIndex for this card. That will allow you to map the current channel card back to a chassis card.
