I seem to be forced to use NAT
Apr 16th, 2007
I am trying to access a Citrix Web Interface server connected to the DMZ interface on my ASA 5510.
The only way I can get it to work is by setting up a static NAT for the Web Server. I don't want to have to do this. I want to be able to access it by it's correct IP address.
When I remove the NAT rules, I can't acces the server, but when I set up the static NAT I can access it and everything works fine.
Am I going to be forced to use NAT for any servers on the DMZ? Or am I just missing something fairly simple here?
Config attached.
John Morgan
tcscadmin Mon, 04/16/2007 - 10:03
Remove your static NAT rule and put:
nat (DMZ) 0 CITRIXSERVERIP 255.255.255.255
or host CITRIXSERVERIP if your PixOS release supports it.
