SUFFIX at the end of the digits
Apr 16th, 2007
Hi ;
we have a satellite solution for outbound calls. 2 lines are connected through fxo ports. But, it is recommended to push # button at the and of the digits to show the satellite that it was the last digit. When i try with an analog phone without ip phone system, it is successful. But i can't push #, when i try from ip phone. CM doesn't let me use #. Therefore, users shouldn't push #, it should be written automatically. I should put a suffix(#) at the end of the digits, but i don't know how to. I know how to put a prefix at CM or router. However , not suffix..
My system: CM5 + 3845 h323 router
Overall Rating: 4 (1 ratings)
jbarcena Mon, 04/16/2007 - 09:47
What do you mean? CCM does allow you to use #
You can set a RP 9.!# that way you can press the # once you have finished with your digits.
