Port Mirroring and Surf Control
Apr 16th, 2007
I have not been able to mirror firewall traffic to surf control since we changed switches to catalyst 4506. I have the following commands entered where Gi5/23 is the firewall interface and Gi5/12 is the SurfControl interface:
monitor session 1 source interface Gi5/23
monitor session 1 destination interface Gi5/12 ingress vlan 150 learning
sho monitor detail
Session 1
Type : Local Session
Source Ports :
RX Only : None
TX Only : None
Both : Gi5/23
Source VLANs :
RX Only : None
TX Only : None
Both : None
Source RSPAN VLAN : None
Destination Ports : Gi5/12
Encapsulation : Native
Ingress : Enabled, default VLAN = 150
Learning : Enabled
Filter VLANs : None
Filter Addr Type :
RX Only : None
TX Only : None
Both : None
Filter Pkt Type :
RX Only : None
Dest RSPAN VLAN : None
IP Access-group : None
Any ideas on why it's not working?
Mary
csisadmin Mon, 04/16/2007 - 12:43
Further on this .... The network card on the surf control server is receiving packets. It just isn't doing anything with them -- no send packets and nothing appearing in surf control.
Mary
robertandreu Tue, 05/01/2007 - 07:44
We moved SurfControl off of the hub to a Cisco 3750. What we did different is we made the source VLAN 1 (data VLAN) and made the destination the port where the SurfControl server is connected to. Hopes this helps.
csisadmin Tue, 05/01/2007 - 08:49
What finally did it for us was adding encapsulation parameter to the destination.
I'm still a little unclear about which VLAN I should be using -- do you create one specifically for that port or use one that's already in use. We've got 6 VLANs in use.
I used VLAN 150 because that's where the destination port is assigned already.
It is working now, so I'm not going to mess with it.
Mary
