Stupid question re: deleting a file on a switch
Apr 16th, 2007
So lets say someone fatfingered the filename of a bin file on a switch. The filename instead of being just filename.bin is instead \
How in the world do you delete that? Is there an escape character you need to use or something?
pciaccio Mon, 04/16/2007 - 11:42
Try the following, (assuming it is in the bootflash directory)..
Delete bootflash:
Todd Kelly Mon, 04/23/2007 - 10:26
If you have CatOS you will need to issue the squeeze command also.
royalblues Mon, 04/23/2007 - 10:32
You can either delete the flash file or rename it
delete flash: or delete bootflash:
rename flash:
HTH, rate if it does
